EV Chargers located at commercial premises - or lack of?
https://www.cornwalllive.com/news/cornwall-news/touring-electric-coach-stranded-eden-5524525
Oh dear!
The Shell 170 kW charger is a big beast, a couple of those would likely hit the local network? Although perhaps not that day...
Clive
  • Agree that supporting charging from a standard AC supply would be prudent.
    A 43 kw charge rate overnight would fully charge the battery. A three phase 63 amp supply is fairly easy to arrange almost anywhere.
  • There seems to be something overly-complicated (or just brittle) about the protocols used on the Type 2 chargers, as fitted to most EVs in Europe.  It's supposed to allow the EV and the charge point to agree on what's the best charge rate, given the capabilities of the vehicle and the charge point.  But it seems that whenever the manufacturers produce new vehicles, it breaks compatibility with older chargers.
    I suspect a big bus, with a huge maximum charge rate, just confused the chargers, which didn't know how to handle it.
  • It seems to me that the whole business of charging electric vehicles has been made over complicated, and therefore more costly and less reliable than one might hope for.
    It would have been better in my view for the charging circuit to be built into the vehicle, and only requiring the connection of a mains input. A simple mechanical keyway on the connection could "tell" the charger what supply was available. A choice of four supplies would meet almost all requirements.
    Single phase 13 amp
    Single phase 32 amp
    Three phase 32 amp
    three phase 63 amp.
    For trucks, buses and electric trains, perhaps add 125 amp at 690 volts.
    broadgage:
    This is essentially what we have for AC charging, only with a simple analogue control signal rather than a keyway, and a couple more options, add 1x16A and 3x16A* to your list, and replace 1x13A with 1x10A as that's what all the granny cables do. This system is fine and works, with a simple pilot signal that encodes 6-80 A available, and a couple of other checks like PE continuity and the ability to check the CCC of a user-supplied cable with a built in ID resistor.
    For what it's worth there's no longer a mainstream car on the market that supports 3x63A AC charging, newer Renault Zoes have dropped it as an option in favour of DC. 3x32A is still common on many vehicles. I suspect the main issue is that American charging stations and cars with type 1 connectors don't support 3 phase at all so the market is more limited. I am inclined to agree with you that wider support for high power AC charging is desirable, simply because the charging stations are simple, low-complexity connectors not huge banks of power electronics. That makes them cheap to install which is clearly important for rollout.
    DC charging is messier as the power conversion is handled off the vehicle and there's a completely different protocol to communicate between charger and car. It also means a given charging site needs a separate bank of power electronics per car if it is to charge more than one at once because they will each need a different voltage and current setting.
    From a user perspective by far the biggest thing that needs fixing is payment, which has generally been a mess of supplier-specific accounts with phone apps or RFID cards. Contactless payment is slowly improving this. Failure to charge is commonly related to payment issues, with the charger or a smartphone failing to connect properly to some remote server.
    *Common in many countries where we would use 1x32A and referred to as an 11 kW charger.
    Edit: fixed typo
  • RichardCS2:
    3x22A is still common on many vehicles.
    Is that a wee typo? 3 x 32 A = 22 kW?
    I am a little surprised that it is commonplace, but EVs are not exactly my specialist subject. Having just bought a new (petrol) car, I shall not be rushing to buy an EV, although my next car may well be one.
    Chris Pearson:
    RichardCS2:
    Well spotted, now fixed.
    As I understand it 3x32A is common because it covers multiple markets - it allows single or split phase 7 kW charging (UK, USA) and 3 phase 11 kW charging (bits of Europe normally having low current three phase supplies) which are both common approaches in different parts of the world. Actual use at 22 kW is something of a bonus that drops out of that. There's at least one manufacturer who does it by having three 16A single phase chargers and using two for 7 kW single phase and three for 11 kW three phase, not giving a 22 kW mode.
  • broadgage:
    Single phase 13 amp
    Single phase 32 amp
    Three phase 32 amp
    three phase 63 amp.
    But that doesn't allow for dynamic charging rates.  That could be a bank of roadside chargers, all fed off a single supply, or else a domestic charger sharing a 60A house supply with all the other appliances.  Type 2 charge points should be able to re-negotiate the power availability on-the-fly.
  • It seems that manufacturers of electric cars are STILL not on the same page. All this stuff about charge rates and supplies is not the big problem, and DC charging just throws another difference into the pile. Why have they got such incompetent system architects setting the charging methods? I only want class 2 cars, that is also too difficult apparently. It is not difficult to design a charging circuit that can accept any of these supplies, with high efficiency. It is not difficult for the car to communicate wirelessly with the charging point, or expensive. It could be Wi-Fi, Bluetooth, or a special protocol, most cars already have these connections. We just need a common 3 phase socket, connected to whatever is available, be it 440V 3 phase or 230V or 110V single-phase or whatever.
    Your car then sends its serial number to the charging point, the driver checks the right reg. number is returned by the charger, the car negotiates the available supply, on a real-time basis if you like, and you are charged on your account. Simple enough, and fairly hack and foolproof. This is how networking and charging should work, a great pity that they don't! Existing cars can still be charged, they just need a protocol adapter lead which would be fairly cheap.
    All new cars should also be class 2, which is also cheap to implement!
  • davezawadi (David Stone):
    Wireless risks all sorts of problems when you have a row of chargers.  You could easily find that every car on a row of chargers is in range of every charger.  How do you ensure that the right driver gets billed for the right car?  The charging leads already in use have pilot wires, which can be used for a serial link.
    Tesla have got it right, if you're using a Tesla car on a Tesla charger.  You plug in the car, it identifies itself to the charger, and you get billed automatically.
    But we're now stuck with a legacy of many thousands of existing cars, as much as 10 years old.  We can't just scrap them all, because we want a new charging system.  So the manufacturers keep extending the existing charging system to incorporate faster charging, including DC charging, and hitting endless compatibility problems with the vehicles already on the road.
  • Simon, you haven't read what I wrote very carefully. The wireless reads the car VIN number, checks the owner and plate number, and checks with the driver this is the one to charge. Wireless is simple and very reliable, much more so than this 1 pin communication lark. As you say the Tesla system is good. It could adapt to any other, older car with a short "smart" socket conversion lead.
    DC charging is a weight bodge, it saves a few kilogrammes but needs yet another charger, plug etc. It is a bit like running oil-fueled cars with about 10 different fuels, it WILL die the death and this method will take over because it better, cheaper, and much simpler. No cars need to be scrapped, just a short cable and you can use any charger (even a Tesla one) anywhere. You see the manufacturers don't really want any compatibility, except that they don't pay for the chargers or infrastructure. It is probably time that they did
    I suppose you know that the signalling system means that the charger needs a much more expensive RCD because it is basically DC? The whole lot is simply rubbish design to reduce the manufacturer's cost by a few pounds, at the expense of others. It is not even a proper comms interface, just simple DC levels and tones, why not ethernet or even RS232? Because it saved a few pence I suspect!
