Maximum permitted Insulation Resistance values HV
Hi all.
Can anyone provide me with minimum permitted insulation resistance values for the following voltages and the standard (if any0 that references these values ?
3.3and 11kV
Many thanks
  • On what? a transformer? A single insulator., dry prior to installation?
    an overhead line of several km, exposed to wind and rain, same again in a coastal location? All 3 will be wildly different .
    A transformer bare and brand new should be some few hundreds of megohms but core grounding methods and internal components such as switches, fuses, and taps may lower  the results of insulation resistance tests.
    A bare bush or  insulator will be gigohms dry and brand new. Covered in salt spray and struggling, a lot less !!
     Brand new paper or XPLE Cables are normally charged to a DC comparable to the peak AC and the  leakage current monitored for some minutes. There will be some dielectric absorption, but current should settle to well less than 1mA per km. Once in service, it can get a lot worse before things need to be replaced.
    DNOs usually have their in-house standards  example https://www.spenergynetworks.co.uk/userfiles/file/SUB-02-613.pdf
  • There isn’t a single minimum IR for HV use the OEM limits and judge by temperature corrected readings and trend. As a rule of thumb, clean or dry new gear at 3.3 kV or 11 kV should be up in the GΩ range; readings down in the low hundreds of MΩ merit a closer look. For motors, follow IEEE 43 modern form wound: ≥100 MΩ at 40 C; random wound: kV + 1 MΩ). If OEM data is missing, the NETA tables are a practical guide.
