Hydro sites conversion to Pumped storage sites
We need to make the most of our hydro by converting the sites into pumped storage energy farms.
This is possible if we can float solar PV panels on the water and erect wind turbines nearby.
Great advantage is hydro sites already established, electric grid connection available at little cost.
Universities with nearby hydro could head up paperwork plans for government funding.
CliveS
  • I've been pondering along similar lines for a while. Unlike the flatter south/east around these parts we have lots of exiting reservoirs often two or three of them in a chain down the same valley with usually many tens of metres head between them. The energy storage from each wouldn't be huge, but over many such project it could add up. As you say, much of the expensive "Civils" has already been done. I can see some objections from the Water companies, as a little of the peak capacity would need to be lost to accommodate the pumped water - but arguably we should be leaving some spare space in reservoirs to accommodate excess rainfall and reduce downstream flooding anyway.
  • Most of the existing hydro sites fail to have any 'lower' pool that stores the discharged hydro water. Dams are built upstream of the big drop and then flows away after generation discharge.
    The few pumped storage schemes use existing natural pools / lakes / lochs and then add an extra high level pool/dam for the short term storage.
    Living directly below the Faskally dam and hydro generation on the Tummel scheme, I get to notice these things. Lots of discussions, and awkward reflections about the influence of "Improvers" of local living conditions.
    Plenty of activity here in Scotland on the multiplicity of 'renewable' schemes and cross fertilisation between them (Big wind farms feeding local pumped storage and onward transmission limitations..)
  • A fun read is Paul Burgess's "The Pumped Storage Hoax" pdf with it's 100% pumped storage as the strawman for knocking down.
    Also, his 'real world efficiency' confuses round-trip efficiency with from-storage-to-generation efficiency (the pump part is earlier).
    It also totally forgets the overarching need to reduce CO2 and consequent global warming/climate change consequence (less winter snows, less water in the hydro schemes, Catch 22).
  • Yes, Scotland is leading the way but our universities are not advising post graduates and doctorate students to concentrate on preparing and costing energy saving schemes, which could be pushed forward to be funded by governments.
