- Vastly reduced energy consumption in the UK, fewer new power stations.
- Maximum home comfort, no more cold or hot or damp homes.
- Due to 2, a large reduction in visits to hospital reducing costs to the NHS.
It is obvious to any building services engineer that the Great British Insulation Scheme will cause mould as insulating a building seals the building.
That's not an obvious consequence at all. That's because it confuses ventilation with insulation.
I would agree that many in the insulation industry and trades are unaware of the confusion and can fire off stupid ideas about how great their little bit is without realising the other aspects that are needed for a more optimal system.
And that's all before the ignorances (not knowings) of the great British pubic and media.
Having had to replace the rotten floor in a ground floor room, resolve gutter, down pipe and drain issues, have a roof replacement (rotted sarking on North aspect), cavity wall insulation, solum covering ('seal'), added window vents, created my own dampness chart to help inform, etc., I feel slightly able to comment...
One of the big problems is that historically, we heated the person (Tea & woolly jumpers), and the room (fire place, curtains & pelmets, closed doors & sausage dog draft excluders), condensation and jack frost on the winter windows.
We (the public) have totally flipped to expecting shirt-sleeved open plan living, with background heating, but still keep doing all the old household habits based on high air flow leaky housing (e.g. clothes drying on radiators and banister rails, sealed double glazing, etc).
A recipe for disaster (as you highlight!).
Insulation isn't the problem. Understanding the trade-offs and learning the appropriate life-style is. There are some great lectures from Dr J Lstiburek that cover some of those trade-offs (and UK's oceanic climate is a difficult environment)
(the Dampness chart is in previous discussion RE: Structural thermal storage )
I think you've got the right general idea there - but I'd take issue with a lot of your details, and there are many more options than you seem to suggest.
As I understand it RAAHPs will only remove moisture from the room when they're in cooling mode (when the coils are cooler than the dew point so condensation is formed) - so most of the year they will be ineffective as a means of controlling damp. Radiators can certainly work effectively way below 80 degrees - we've been designing for system temperatures below 60 degrees since the introduction of condensing gas boilers decades ago - increasing the sizes of radiators again to better fit heat pump characteristics is certainly possible (and is done). Another option is wet underfloor heating - certainly for new build and major referb projects - the "warm toes" effect often allows slightly reduced room temperatures while preserving comfort and the lack of noise and even heating is often appreciated by consumers. Wet heat pumps can easily produce 55 degrees plus (some can go as high as 75 degrees) so can usefully heat domestic hot (tap) water too - and significantly more efficiently than an immersion heater or electric boiler.
As for moisture control, my preference is whole house heat recovery mechanical ventilation. Unlike single room units it naturally draws air right across rooms rather than trying to ventilate a whole room from a single point, and can use excess heat from bathrooms and kitchens to pre-heat the rest of the house. Again more easily fitted in a new build or major refurb situation, but an option all the same.
Thinking more about this, while it should, I suspect often it doesn't. Ventilation to suspended timber ground floors needs to be maintained, which in many older properties means the wall cavity is also ventilated (as air bricks traditionally weren't sleeved as they pass through the outer walls), then inevitable gaps around joists where they are supported by the inner leaf of outside walls (or gaps around pipes or just missing bricks) means the air flow can continue into floor voids, and often into the loft space as often the top of the cavity wasn't closed either. I've even found draughts coming up the underside of staircases - as there was a gap between timber staircase itself and the lath & plaster angled ceiling below it - which effectively joined the underfloor area to the landing floor void. Insulation can be tricky to do properly.
Answering Andy
RAAHPs re mainly for heating and at press of a button can cool or just dry. Heat pumps most efficient temperature is 30C no good for radiators
In my blog I am talking about external insulation and double glazing sealing the building which prevents enough ventilation to allow for the damp from breathing, sweating, bathing, cooking etc. being expelled from the building which is what happens under the Great British Insulation Scheme and how to overcome it. The ventilation and draughts you mention are another discussion that I hope others take up.
John
That shouldn't happen though - building regs (part F) generally demand suitable ventilation see https://assets.publishing.service.gov.uk/media/61deba42d3bf7f054fcc243d/ADF1.pdf and the Domestic Ventilation Compliance Guide) - and that would apply (at least to the extent of not making things worse) to changes to existing buildings as well as new builds (e.g. when fitting new windows). If there's not better solution the the minimum would normally be trickle vents in the windows - so not really sealed at all. (Of course regs aren't always complied with, but that's a different issue).
Moisture isn't the only problem ventilation solves either - presuming you have living breathing occupants then there's oxygen to replace and CO2 and all sort of indoor pollutants (from odours to spores) to expel. I'm not sure RAAHP would achieve all that, even if it switched modes automatically.
HP efficiency is certainly best at lower flow temperatures, but that doesn't completely rule out radiators with heat pumps. Larger radiators can still provide sufficient heat to a room even at reduced flow temperatures (say 45 degrees ballpark) - even better when the place is properly thermally insulated as heat demand will be lower than before. Many wet heat pumps have optimising controls that allow them to vary flow temperatures depending on the difference between indoor and outdoor temperatures - so when it's less cold outside, and so the rooms need less heat to keep the temperature up, the HP reduces the flow temperature and benefits from improved COP. In the depths of winter the efficiency drops but the costs are still manageable over the year. There are certainly radiator based heat pump systems being installed and they do work. In many cases other options may well be more efficient, but they're still an option.
Don't get me wrong, RAAHPs certainly have their place, and their USP of being able to provide cooling as well will certainly appeal to many at the moment (even if other methods, e.g. external shading to windows might be a better solution or at least contribution). I suppose I'm cautioning against over-egging their advantages or disregarding valid alternatives - such tactics soon gets seen through and then the valid parts of your message risk being disregarded too.
I agree with you, but I am puttng forward that The Great British Insulation Scheme done properly to achieve STS seals the building. If adequate ventilation is provided STS can't be achieved and the insulation is inefficient. The only way to achieve STS is to install heat recovery extract fans and RAAHPs that can provide hot air at 30°C or cold air at 16°C or any temperature in between, whatever the temperature is outdoors, at the turn of a switch and they remove water from the air at the same time. The air inside the building retains it's temperature therefore not wasting huge amounts of energy and are very cheap and easy to install. I have had the STS, RAAHP system installed in my home for 10 years and i have been very confortable and had very small energy bills,
Andy.
Radiators are now obsolete, They are inefficient, take along time to respond and cost many times the price of RAAHPs to install.
I think I may have given the wrong impression regarding ventilation to suspended timber ground floors. The suspended timber ground floors are normally sealled in relation to the air in the rest of the house with flooring/carpet, so are not a problem, as long as the insulation does not block the air bricks. As heat rises the losses of energy to under suspended timber ground floors are small and can be compared with the loss through the foundations, double glazed windows etc.
John Greengrass
