Sparkingchip:
That's a positive head pump, think twice if you are supplying it.
Is the tank considerable higher than the shower outlet and is it a thermostatic mixer shower?
If the answer is no and yes, fit a negative head shower pump.
Legh Richardson:
I would have thought a generic pump motor would have a start up current up to 8 times the full load current. On the surface it may not trip as its below the instantaneous tripping current rating of the MCB. However, I have seen 2 times 300W lighting transformers take out C6 breakers. So perhaps I'd rate the MCB for this particular job at C6.
Sparkingchip:
Why not a B16 at the consumer unit feeding a 1.5mm t&e circuit and a switched 5-amp fused connection unit to provide the final connection to the pump flex and provide local isolation?
Andy
