					I would use 3no Quadrafoil Groups - you don't say what ampacity you want but for up to say 2.0MVA the quadrafoil would be easiest for you
Google that and look for Ellis Patents cable cleats
For each of the 3 groups try and contra rotate the phase conductors - each group of 4 contains L1, L2, L3 and N
OMS
So there is no problem with having a neutral on the outside of the last group? The reason for the question is IET GN 6 implies the neutrals should only be installed between groups. Therefore, this would only allow two neutrals for three groups, if you follow?
					A report produced by ERA on behalf of Ellis delivered the following guidelines:Current ratings, given in BS7671, for cables in touching trefoil formation are (also) appropriate for cables in quad bundles. Derating factors, given in BS7671,for cables in touching trefoil formation are (also) appropriate for cables in quad bundles. Voltage drops for circuits in quad-formation should be calculated using the values tabulated in BS7671 for cables in flat touching formation When considering multiple cables per phase, the advice given in Guidance Note No.6 for trefoil groups is applicable to quad bundles. The induced voltage in the neutral conductor of a quad group is minimal and can be ignored.
