Kitchen referb,rewire,heat detector?
As above,I was wondering if a mains/battery heat detector was compulsory in this situation.
I was going to recommend one to the client.Other detectors in the house are just battery powered,not linked.
The site is in west yorkshire.
Thanks for any advice,
                                 Regards,Hz
  • You need to be careful with this because kitchens may get very hot and alarms by accident are a real pain to everyone. A rate of rise temperature sensor is what you want, but I have never seen a stand alone one, only types for full fire alarm systems. A smoke detector outside the kitchen is probably perfectly adequate and a lot less trouble.
  • Is the kitchen separated from circulation spaces by a stairway or door?
  • Yes,a kitchen door.Have never had a problem with false alarms with heat detectors in kitchens, only smokes outside the kitchen door  .Regards, hz
