Used Alkaline LR6 AA Cell Voltage
I find it interesting that used alkaline cells, when used as a pair exhibit near identical voltages.
Typically, two Mitsubishi LR6 AA cells, removed from a wireless room thermostat, one 1.478 volt the other also 1.478 volt.  Not the first time I have come across this.
Similarly, two brand new, unused Duracell Industrial Alkaline AA cells, both 1.600 volts.
All four cells tested off-load.
Clive
  • Can your voltmeter really measure to that degree of accuracy; and if so, do you need it?
    But I do take the point, modern cells in series do seem to discharge evenly, but not always.
  • Chandeliers with lots of GLS light bulbs, when they started failing you could see the lamps out of the same pack as the adjacent ones failed, because the manufacturing tolerances were so close.
    Andy B.
  • If they are used in series, you are really comparing the manufacturing tolerances of identical plate areas, so the cell capacity is the same, and for low current applications like the thermostat and clocks, the self discharge rates, which is mostly about contaminants and factory cleanliness.
    I'd expect cells from the same date batch by a reputable make to be matched quite well. No name cells or varying batches far less so.
    I am in the habit of writing the date in pencil or sharpie on things like clocks smoke alarms, and so on, so I can see if the rate of discharge is constant. It often is to within perhaps a  week in more than a year  or so, suggesting matching across batches from the same maker is also good.
  • Whether my voltmeter is accurate, I do not know. But the readings are certainly repeatable.  I shorted the probes together after each measurement to ensure that the meter did not attempt to hold the last measurement.
    Rechecking again just now gives me: 1.600v for both new and 1.479v for both used.
    The meters claimed accuracy (when new) was +/- 0.25% +5dgt DCV accuracy on its 400mV range and +/- 0.4% + 1 dgt on the 4.00V range which I used.
    Clive
