Sparkingchip:
The one flat I moved the lighting to the RCD protected side of the consumer unit, in the other I swapped the main switch out for a RCD, a quick fix in both flats.
So both flats now have all their circuits protected by a RCD removing several observations and codes from the EICR.
I won’t be able to do something like that every time, so some will have to be coded.
Make a determination.
Andy Betteridge
Trying to balance risk of danger from livened up metal parts and risk of danger and inconvenience from all ccts on one RCD: perhaps not an easy choice to make while also factoring in cost.
