mapj1:
Remember that in the UK the regs are non-statutory, and in other technical fields there are plenty of abandoned standards (some BS, some EN some ANSI) that no-one follows any more for one reason or another, because they were inadvertently locked to one way of doing things that is simply not used in practice.
whjohnson:
So how would you code the lack of one for an EICR? Would you fail the installation?
Good question and I take the point! The argument for SPD (save in a hospital) is purely economic, so no code or C3. AFDD is intended to improve safety, but without it, we still have two faults required to danger so could not be more than C3.
If you want to be very strict, you could argue that the absence of recommended AFDD already requires improvement so C3! ?
AJJewsbury:AFDD is intended to improve safety, but without it, we still have two faults required to danger
Two faults to danger from electric shock, but perhaps not two faults to danger from fire?
Which is why I would be more inclined to code absence of AFDD than absence of SPD.
Now then, which is a better means of detecting a dangerous arc fault - inspection or AFDD?
