Harry Macdonald:
It is worth thinking about what you need as opposed to what would be fun but expensive.
With LED lights, you should be able to light the house adequately for about 100 hours from one Lead Acid battery.
Maybe worth adding an inverter to run the Central heating controls.
Sound advice except that at 60 - 80 W, the pump wouldn't last more than a few hours.
wallywombat:
If you're concerned about a major and possibly prolonged infrastructure failure, then I'd suggest a wood-burning Aga or similar with a large stock of firewood!
Got that! I have three or four pallets of wood from home and neighbouring tree felling. But if there were to be a major infrastructure failure (this week? ? ) what would I eat? ?
Answer is home-grown veg. Food inches folks! ?
jcm:
I was looking (out of interest) for what size of generator to charge a EV. Well not the small inverter generators you see in those German supermarkets you could put in the boot. Alas you may need something like a wheeled portable generator / welding set you could tow behind the car. However you could use red diesel to charge your EV car and van.
Below is the information site I was looking at for the size needed to run your house (without EV charging point.
generatoradvisor.com/.../
This post is not as stupid as the Government doing away with Petrol/Diesel /gas . Did you ever see as many cars , lorries and vans on the road as there is today no one working just running around in cars (including myself)
Tom a lot of the old hands have now left the forum , glad to see that you are still there.
Regards , I am going for the jag , get yours to . Hopefully be a happy Christmas next year
then we can wish it on all who are left.
jcm.
A "granny lead" with a 13A plug on the end will draw 2kW. A wall mounted charger will be 3.6 or (usually) 7.2kW.
If you're running off a generator, it will need to be stable enough to keep the car happy, and the chargers have built-in earth fault detection. So it may refuse to charge at all off a small generator unless the wiring's right.
