AncientMariner:
His excuse is that he was not given the architects plans showing what was required, in reality what was wanted was by discussion and with locations etc marked on the walls before wiring and plastering.
So as per my post title, who is the electrical installation designer? Who is responsible for drawing up a diagram of what is wanted/required? The property owner is not electrically qualified.
It's all there somewhere in the contract, but disentangling it may take some effort.
If the quote was for a fixed price, that is all the electrician is entitled to; but if it was an estimate, the customer will have to pay up.
I would say that in terms of an EIC, the designer is responsible for ensuring that the installation is compliant and no more.
In an ideal world, the architect should have agreed the lighting arrangement with the customer and ensured that sufficient information was passed to the electrician; but I think that a walk around with position of back boxes chalked on the blockwork could be sufficient. If the customer did not specify exactly the bedroom switching arrangement, it sounds as though the electrician has made a reasonable interpretation.
The customer paid on completion of first fix. That suggests that the customer was satisfied with the first fix.
I wouldn't want to deal with self-builders on a regular basis!
AncientMariner:
And of course, what should the person who contacted me (property owner) do?
Ask the Client or the Principal Contractor who the Designer is for the Works. They should know under CDM Regulations.
If it's a "domestic client", then the Principal Contractor takes on the responsibilities of the Client ... so it's all down to them.
If the "works" is only the electrical installation work, which might be the case here, it's all down to the electrical contractor / electrician.
Now, here's the rub for the poor electrician/contractor. If the works were more extensive than the electrical work, and they failed to ascertain who the Principal Contractor or Designer was, they were not legally entitled to start work under CDM Regulations.
So, in essence, the question always comes back to the electrical contractor / electrician, and I think the burden is on them unless they can demonstrate otherwise. I don't think it can be the Client for a "domestic client".
gkenyon:
If it's a "domestic client", then the Principal Contractor takes on the responsibilities of the Client ... so it's all down to them..
I have to confess that I was unaware that CDM applied to small or even not so small domestic projects. HSE guidance, which is worth reading is here. It says this about domestic clients:
Domestic clients
If you are having work done on your own home, or the home of a family member, and it is not in connection with a business, you will be a domestic client. The only responsibility a domestic client has under CDM 2015 is to appoint a principal designer and a principal contractor when there is more than one contractor. However, if you do not do this, (as is common practice) your duties as a domestic client are automatically transferred to the contractor or principal contractor. If you already have a relationship with your designer before the work starts, the designer can take on your duties, provided there is a written agreement between you and the designer to do so.
Given that this work is for a holiday let, it is difficult to see how the client could be a "domestic client".
My understanding of the Regulations (which are not excessively long) is that the responsibilities of the Principal Designer are to ensure that the programme of work is safe and that work complies with the appropriate standards (including BS 7671). I don't see any statutory duty to ensure that the design does what the client wants it to do. That is a matter of contract.
