I need to rely on the electrician who installed the cable when the house was constructed has fitted the appropriate MCB and the electrician who carried out the inspection last year properly certified it as so.
We must not forget that a cable run is largely not visible and can run through thermal insulation. Also the inspection and tests are often just small percentage samples of the whole installation, except final circuit testing. What may have been o.k. then may not be o.k. now with new loads added.
Zoomup:
32 Amp circuit recommended for the hob.
https://www.bosch-home.co.uk/product-list/cooking-baking/hobs/induction-hobs/PXV851FC1E
Where did you see the 32A recommendation Zoom? I can't see any mention of it on that page or in the installation instructions - http://media3.bsh-group.com/Documents/9001093674_E.pdf.
I know some retailer sites make such recommendations, but their choices seem to be limited to either 13A socket or 32A hard-wire.
biglouie:
I am not an electrician, I have not been trained, not passed an exam nor do I have years of experience.
OK, the majority viewpoint in here is that the existing circuit is suitable.
So what work needs to be done?
And who is contracted to do what?
AJJewsbury:Zoomup:
Z.Where did you see the 32A recommendation Zoom? I can't see any mention of it on that page or in the installation instructions - http://media3.bsh-group.com/Documents/9001093674_E.pdf.
I found this listing.....
Bosch PXV851FC1E Induction Hob, Black |
(5)
Induction hobs heat the pan not the hob using an electrical current. Induction hobs can heat a pan faster than a traditional gas or electric hob, and are more energy efficient. They’re also easier to clean, as you can wipe the hob shortly after using it. Remember, not all ceramic hobs are …
"Amperage: 32A
Aperture needed: H5.1 x W75 x D50cm
Brand: Bosch
Burner Power: 1x 1.8kW, 1x 1.4kW, 1x 2.2kW, 1x 3.3kW or 2x 2.2kW
Cable Included: YES
Control Position: Front"
