davezawadi (David Stone):
Induction hobs take power in response to the size of the pan and the temperature set, so several 'rings' at full power for long is unlikely, as is the oven being on maximum for more than 5-10 minutes.
I take JP's point and if the manufacturer's instructions say it should be on something bigger than 6 mm², there is a problem. However, I very much doubt that they will say 6 mm², but not shared with anybody else.
I have two cookers, an old commercial range (70 kW), which came with the house, and a commercial combination microwave (3 kW). I allow 20 minutes for the big oven to get Yorkshire pudding-hot. It's nearly Easter, so if I put in a lamb, the temperature would drop and the burners would probably go full on for another 10 minutes, by which time they will turn down and maintain the temperature. At equilibrium, the burners are only chugging along at the rate at which the insulation allows heat to escape. Similarly, once your pan of potatoes is boiling, the only heat required is to match the losses through the sides and top of the pan (+/- lid).
I think that the OSG diversity figures are pretty reasonable.
What size circuit would you instal for a single load of 6.3 KW or 27 Amps
Diversity should not be applied to circuits supplying individual appliances to select the supply cable. The cable should be sized in accordance with the manufacturers instructions or the plated rating. Diversity factors should be used for distribution circuits or the whole installation. Yes I know that the OSG says something that reads differently but I would not mind betting that will change in the next edition.
AJJewsbury:What size circuit would you instal for a single load of 6.3 KW or 27 Amps
In this case though it won't be a single 6.3kW load - a single domestic oven doesn't take anything like that - most likely a double oven, perhaps including a grill in one of them - so more like 3off 2kW loads or at worst 2off 3kW loads - so I'd say there's a good case for diversity even within the one "oven".
I was presuming a single large oven of 6.3 Kw loading. If in fact this is two ovens or two ovens and a grill with a total 6.3Kw loading, then I agree with your remarks.
Two ovens and a grill, and several cooking rings is indeed comparable to a standard domestic cooker, even if the components are in seperate cases.
32 amps might be reasonable in such a case, such circuits have a good record in practice. 40 amps might be better if heavy use is expected, and 50 amps is almost certainly OTT.
