Chris Pearson:Zoomup:
I kept all of my original hair. No shocks or explosions occurred.You and BOD are getting very unruly. ?
What I want to know is whether the motors will go round and round in the correct direction. ?
The word is 'are getting' emotionally close.....
I have a solution to Zoom's dilemma, I've been chatting with one of his relative's, Zoom, and it was suggested that he should use a electronic tracker, as Andy suggested. The one we use has no torrid coil detector so has to be hard wired in series. We once used it to good effect, followed a very interesting cable route and a couple of buried JBs. The tracking instrument is french at a frequency of 25kHz, but works perfectly well on UK electrical circuits. It does help if you can understand French instructions.....
Legh
The new machine is to be delivered nest week. It is a sort of chop saw thingy that mitres the corners of double glazing U.P.V.C. unit edges. I haven't seen it yet. I suppose that if it rotates backwards it adds material rather than removing it.
kfh:
Well done.
All the farms around me I have been on are PME even when they are dairy with PME milking parlours. It makes any modifications difficult. Not so many still milking though.
That is interesting kfh, What astounded me though was that the main three phase cut out has two S.P. Henley blocks placed side by side connected to Neutral, by the main fuses. They are linked together with a very short length of 16mm2, or imperial equivalent, cotton covered single cable. These two Henleys are used as earth terminals. How does that date things Watson?
AJJewsbury:That is interesting kfh, What astounded me though was that the main three phase cut out has two S.P. Henley blocks placed side by side connected to Neutral, by the main fuses. They are linked together with a very short length of 16mm2, or imperial equivalent, cotton covered single cable. These two Henleys are used as earth terminals. How does that date things Watson?
I've seen setups like that in rural areas (or more likely both N and PE into one Henley block) - often PNB rather than PME though.
There is a single black cable running from the Henleys down
into the ground, possibly about 16mm2. The supply is from newish A.B.C. overheads.
Edit. Add. So Andy, are you saying that the earthing of the Neutral is at the installation head position only and not at the supply transformer star point? Is that P.N.B?
2nd Edit. Add https://www2.theiet.org/forums/forum/messageview.cfm?catid=205&threadid=47661&STARTPAGE=4&FTVAR_FORUMVIEWTM
The PNB discussion is very long and convoluted.
