I have a system similar to this one. I have to measure common mode voltage and current to see how the inverter switching is affecting a common mode voltage and if I need to add common mode filter between the inverter and the motor.
For common mode voltage should I just put multimeter (ac settings) or differential probe between motor's neutral and PE? Would that be the same voltage as between N1 (filter capacitor's neutral) and PE?
How to measure common mode current? It that the same as leakage current? ... which shouldn't be higher than 0.5 mA or 3.5 mA.
