Supplementary Bonding in High Zs Value Scenarios
Recently, I attended a webinar that addressed scenarios in which, due to elevated Zs values, a molded case circuit breaker (MCCB) was unable to achieve the disconnection times within the maximum permissible Zs values. The proposed resolution involved the implementation of additional protection through supplementary bonding exclusively at the intake position. However, one might consider whether this protective measure should extend to all equipment within the specified location, thereby necessitating supplementary bonding at the load end as well. What are your thoughts ?
  • I assume this all about the less than 50V touch voltage between any accessible parts as a protection measure where all conductive parts rise and fall together in voltage  and a voltage difference of less than 50 V is achieved between any parts by supplementary voltage?
    Then, in the above scenario, I’d assume that the Zs is sufficient for all down stream devices so didn’t need an alternative solution such as supplementary bonding?
    Supplementary bonding would work for the load end too if needed.
  • However, one might consider whether this protective measure should extend to all equipment within the specified location, thereby necessitating supplementary bonding at the load end as well.
    In a way there's two different questions there. Actually installing supplementary bonding, vs achieving what supplementary bonding requires. Typically you need to achieve R ≤ 50V / Ia between simultaneously accessible parts. So where Ze is high for instance (and R2 relatively low), you might achieve R ≤ 50V / Ia without actually having to add any supplementary bonding conductors as such - as the local c.p.s. will already achieve what's necessry. Or just supplementary bonding a few carefully chosen items (e.g. those with the longest c.p.c.s) might allow the requirements of supplementary bonding to be achieved over a wider area. Supplementary bonding at the intake presumably looks pretty similar to main bonding (other than the c.s.a.s involved) and normal c.p.c.s. A lot depends on the actual numbers for a particular situation.
  • Seems reasonable on the surface ... but there's a "hidden problem" in some installations.
    One example I can think of, is if the distribution circuit supplied by the mcb is singles in trunking, has the analysis addressed simultaneous contact for the entire length of trunking for a fault at the remote end?
