Ed Throws Trade Bodies Into Chaos Over DIY Solar!
"Ed Throws Trade Bodies Into Chaos Over DIY Solar!"  (efixx)  :-)  lol
Cue another early amendment and Section in BS7671 and   another 'membership' level in the brilliant CPSs for the trade to do DIY Solar installs.
  • But we really lack as a country a good way to store the energy for re-use.  We need a technology to re-sync it back into the National Grid
  • In fact, it looks like wind actually out-generated gas for the 2025 calendar year (from electricinsights.co.uk/ setting for the Sum for 1 Year starting 01/01/2025):
  • As a casing point have you benefitted from Brexit?
    Although that came about not from political policy as such (IIRC the official policies of all the major parties at the time was to remain) but a popular vote (referendum). I suppose you could argue that a policy of not offering the people a direct vote in the matter might have been better. Mind you the population of most democracies seems to have a reputation of voting against the direct consequences of what they voted for last time - so things may change again at some point.
  • https://cn-cob.com/blog-detail/vde-standards-an-in-depth-analysis-of-germany-balcony-power-plant
    Thank-you TurboGen - that was a very interesting read. The Germans seem to have done a very thorough job there - and indeed their logic is based on the extra 800W for the durations PV would be likely to supply won't cause their 1.5mm² conductors on a 16A MCB any serious harm. Interesting to note the some other European countries prefer 13A protective devices. They did have to go to some efforts to show it was safe though, as it fails a simple Iz >= In + Ig test.
    What I'm not clear on yet, is why the German VDE standard writers allow a regular Schuko socket (comparable to BS1363 or IEC60309 plug) to be used to connect an 800VA inverter with upto 800Wp (+20% / 960Wp) of solar PV modules (i.e, panels), but if a 'special energy plug' which appears to be these better shrouded and locking, Wieland RST 20i3 plug/sockets, then the same 800VA inverter can be connected to upto 2000Wp of solar PV.
    I'm guessing, but their workings seem to presume only so-many minutes per year of thermal overload - pairing 2kWp panels with an 800W inverter presumably would mean that the inverter was running at full whack for many more hours - longer each day as it makes better use of dull morning and evening light, less dips in output when clouds pass and much more likely to be generating on winter days. So the thermal damage to the cable insulation would potentially be greater and so less tolerable. I guess the presumption is that a dedicated socket would be connected in a way that overloads could be completely avoided.
  • I disagree
    Politicians mislead the public as to what Brexit would do.  Everybody remembers the bus saying something like
    We send the EU £350 million a week, let's fund our NHS instead" Vote Leave bus
  • Politicians mislead the public as to what Brexit would do
    A minority of politicians perhaps - many others advised the exact opposite. One of the consequences allowing a debate and free speech I suppose. Many of the flaws in the arguments (both ways) were obvious even at the time. Voters are expected to be able to make up their own minds, rather than needing to be "guided" into what's thought to be best for them. Surely every voter understands that there are different points of view and "statistics" can be presented in different ways to match different points of views.
  • I'm guessing, but their workings seem to presume only so-many minutes per year of thermal overload - pairing 2kWp panels with an 800W inverter presumably would mean that the inverter was running at full whack for many more hours - longer each day as it makes better use of dull morning and evening light, less dips in output when clouds pass and much more likely to be generating on winter days. So the thermal damage to the cable insulation would potentially be greater and so less tolerable. I guess the presumption is that a dedicated socket would be connected in a way that overloads could be completely avoided.
    If the 'special socket' had to be on a dedicated radial circuit, that would make sense as the use of a unique plug/socket would then make that a dedicated circuit just for balcony solar / plug-in generation, which is quite a logical approach.
    It would actually work quite well - homes could be built with a dedicated circuit to the balcony, or other suitable outdoor space, with this unique socket installed, ready for the future owner to connect their own plug-in system. And being shrouded on both plug and socket, with a locking connector is arguably better than a regular plug/socket.
    But if the 'special socket' can be wired into an existing socket circuit, the it must relate to something like the stored / capacity energy shock risk on exposed plug pins, lack of a locking connector or long term suitability of conventional Schuko sockets for generation use.
  • It would actually work quite well - homes could be built with a dedicated circuit to the balcony
    Or even with PV on the roof.
    I am dismayed at a development a mile and a bit from here of "up to 99 dwellings" by a major housing association (they have 37,000 dwellings). Not a panel in sight. If anybody needs PV, it's people on limited incomes.
  • Politicians mislead the public as to what Brexit would do.  Everybody remembers the bus saying something like
    Then we had covid-19.
    Clap for the NHS.
    When I was a lad, it was NHS for the clap.
  • One of the consequences allowing a debate and free speech I suppose. Many of the flaws in the arguments (both ways) were obvious even at the time. Voters are expected to be able to make up their own minds, rather than needing to be "guided" into what's thought to be best for them. Surely every voter understands that there are different points of view and "statistics" can be presented in different ways to match different points of views.
    I agree
    I also think that there should be a team/department that does not get altered by whichever government runs the country for a few years and looks at scoping longer term 10 to 15 year technical projects that will benefit the country.  As an example look at the train and rail system in China.  The speeds being acheived are phenomenal
