Chris Pearson:
BS1363-2:2016+A1:2018
<snip>
Section 6: classification and rating
6.1 The rated current of all socket-outlets shall be 13 A
<snip>
Section 16 specifies 14 A + 6 A for temperature testing.
It must be that every BS1363 socket can safely supply 13 A indefinitely because that is what users are entitled to expect of them. Nowhere does it say that the total of a multiple socket-outlet is limited to 13 A. It is not expressly stated, but if a twin socket-outlet may safely supply 14 A + 6 A for at least 4 hours with a stable temperature, it may be inferred that it is safe to do so.
Chris Pearson:
Section 3: definitions
"socket-outlet" accessory having a set of three socket-contacts designed to engage with the pins of a corresponding plug ...
"multiple socket outlet" combination of two or more socket outlets
Am I reading this differently from everyone else? If a 'multiple socket outlet' is a combination of two or more socket outlets and the rated current of all socket-outlets shall be 13A, surely this means a multiple socket outlet with two socket outlets must be rated at 13A + 13A, or 26A for the unit. Or is this wrong?
AJJewsbury:
... e.g. you could take the full 13A from either the left hand outlet, or the right hand one, but not necessarily both together ...
gkenyon:
I've seen similar situations where the plug and socket-outlet are not overloaded, say appliances running at about 2 kW, but bad connections in the plug (loose terminal screw, or, with moulded plug, similar cases such as broken strands on crimps or brazing)
