Sparkingchip:
they don't display the area code because they assume everyone knows it and you don't need to use it from local landlines.
Chris Pearson:
One ought to give a number as 023 9255 xxxx in which case it is more obvious that within 023 land, one may start with 80 or 92. I don't know whether there are any 023 81xx xxxx numbers, but there are 023 93xx xxxx ones, presumably because they exhausted the supply of 92 ones.
Alan Capon:
Unfortunately everyone is still scared of the GDPR legislation, because of its teeth. Fines can be up to 4% of the companies annual turnover, or €20M, which ever is the greater.
Alan.
