'There are two groups of heating glass in your installation and they are controlled by two temperature controllers that are working as a thermostat with a sensor on the glass. When the required temperature is reached then the power will be cut off.
When the sun heats the glass then also the sensor commands the processor to cut off the power'.
I assumed only 2 of the 3 sensors could be used so the south one for all the windows south & west (controller 1 on consumer board) and either the north or east sensor for those (controller 2 on consumer board) - so just 2 zones which was not what I asked for and pretty impractical - hence wanting to try and hook them up to a room stat on a room by room basis (somehow?)
Ian.
I don't see why you have temperature sensors near the windows either,
