Arran Cameron:
Would it make more sense to abolish notification of the LABC for new circuits?
Chris Pearson:
Arran's argument is sound, so in fact we need to stop kitchen fitters, or whoever, adding to circuits which are already fully loaded; or whose OPD may not be suitable for directly connected appliances. The problem is that such an approach would be disproportionate if, for example, the requirement was only to add a socket or luminere in a workshop or shed.
kfh:
I thought one of the drivers for Part Pee was to allow kitchen fitters etc to get qualifications which would allow them to self certify their work when installing additional sockets etc as part of their main work.
While the intention may have been good it allowed a lot of people to register with a scam as part Pee certified and then to take on work outside their level of experience and competence.
There seem to be lot of installations around with spare circuits originally installed that "electricians" have been able to use to get around the notification of new circuits requirement.
Arran Cameron:
kfh:
There is the big question as to what is considered to be an existing circuit. In a similar way that there are roads to nowhere, there can be cables emanating from a CU that come to an abrupt end in a terminal box nearby. Could these be used by the burglar alarm installer or a homeowner who is installing a pond pump and a couple of outside lights in the back garden in order to circumvent having to notify LABC?
Does an existing circuit even need to have any cable connected to it or is it defined by a MCB or RCBO being physically present in the CU even if nothing is connected to it?
mapj1:
It is quite legal and possible to fit and notify a CU with 10 off 1 foot lengths each ending in a JB and no loads connected at all.
mapj1:
It is quite legal and possible to fit and notify a CU with 10 off 1 foot lengths each ending in a JB and no loads connected at all. Everything else is an addition to an existing cct. and non-notifible.
I have wondered if there is a lack of consistency between different LAs over the definition of a new circuit. Examples include:
1. The cable itself - even if it's connected to an existing MCB or RCBO.
2. The addition of a MCB or RCBO to the CU, even if nothing is connected to it but notification isn't required when a cable is finally connected to it.
3. The connection of a new supply cable to an MCB or RCBO, but notification isn't required to install the supply cable or the MCB or RCBO.
Actually it may have been better to insist on inspections at change of house ownership.
And there really is no evidence that accidents have fallen at any faster rate than they were already falling before it was introduced....
