AJJewsbury:
The TRT037N appears to be a programmable thermostat - so why the need for an extra channel from a programmer?
What's the motorized valve arrangements? I'm guessing a simple 2-port spring return for the new zone (and similar for the existing zones) - but there are other possibilities that would make things rather different. (I have a long dislike of 3-port valves but some plumbers seem to like them).
I guess you'd also need the microswitch output from the valve to trigger the boiler (in parallel with all the other zones) - which you probably knew anyway, but as you hadn't mentioned it I thought it best to check.
Sparkymark:
That’s interesting.
All of the underfloor heating I’ve worked with the ufh wiring centre had connections to control the valve, but doesn’t seem to be on this one.
Assuming you have non-programmable room stats then yes I think channel live to the wiring centre.
I think I would then use the PL07 to control the valve so brown to the boiler on terminal, and then the valve to switch the boiler so orange to a separate core back to the boiler.
Does seem a bit long winded though and not familiar with this system, so stand to be corrected...
