EICR C2 on missing RCDs on existing installation
I had an EICR done on my property which I let and currently has tenants in it. The previous EICR in 2020 came back with no observations, so I was very surprised that this time I got C2 on missing RCDs on the distribution board (411.3.3; 415.1), final circuits for socket outlets up to 32 A (411.3.3), concealed cables in walls (522.6.202 and .203) and lighting circuits (411.3.4.), cables passing through zones 1/2 (701.411.3.3.) and for location which requires IP-rating (701.512.2.).
I of course absolutely want to ensure electrical safety and full compliance with the applicable laws and standards in my flat. However I am surprised, that the installation which at the time of completion in 2008 was certified safe and also passed the inspection in 2020, has now suddenly become unsafe due to missing RCD. To my understanding it is rare, that standard updates are applied to existing installations to this extent, and in a manner that requires immediate and extensive updates carried out within 28 days (deadline given on the report). Would anybody be able to confirm if this interpretation made by the engineer is correct, and indeed all landlords in the UK are now required to update electrical systems in their properties, if the RCDs are not present?
Thank you
  • The standards referenced might be in conflict, but surely, in the vast majority of cases, it's possible to design an installation that complies with both (or more) versions?
    The earlier standard may not have considered or mentioned an ISOD, but unless it prohibited it in some way, couldn't current devices be said to effectively comply with both versions of the standard
    I think that Andy has squared the circle.
    So back to the OP, the C2 for no RCD protection on sockets (411.3.3) would have been the same under 17th Edn (although the exceptions have changed); and for the luminaires, 17th Edn was simply silent on the issue - there was no paragraph 411.3.4. Nothing in 17th Edn prohibited RCDs in areas where they were not required.
  • I do not know if there are any RCDs, I have not paid much thought on it as even though I am an engineer and work in construction and have some understanding on the topic, I am not an electrician. I need to see if I can find a picture of the consumer unit. I am leaning towards to have the RCDs put in place, whether by replacing the consumer unit on through other means. It's a 4th floor flat, so none of the sockets are for outside use. There is a balcony, but to bring electricity there, you would need an extension cord with several meters of length.
  • Installation is from 2008 when the flat was built. It's been in residential use, I lived there myself for the first 11 years and after that it's been let, always a couple, however not sure how heavy the use would have been - domestic appliances only. It's at the 4th floor, so none of the sockets are meant for anything external. Even using them from the balcony would require an extension lead of several meters.
    I think I am going to get the RCDs done, but not by this guy who did the inspection. I asked him on Thursday to break down is lump sum quote into detailed line items & cost, and he hasn't got back to me yet. The level of detail on the work he quoted was in lines of "bathroom lights not IP rated, replace with IP-rated ones." I would certainly like to know the IP rating he is proposing to install, and also claiming 'not IP-rated' (as if they were fully exposed) when talking about LED-spots integrated within the ceiling is not professional. I understand it's the easy way when speaking with people who understand the context, but absolutely not a proper way to communicate to your customer what the current status is and how it needs to be upgraded.
  • It's a 4th floor flat, and bringing electricity to balcony would require extension lead of several meters.
  • Hi John
    the flat is at 4th floor and an extension lead of several meters would be needed, if electricity was to be brought to the balcony.
    I find some relevance in when the flat was completed, as something installed in 2008 is much safer than an installation from let's say 70s, which are still around. But I am of course not claiming that this makes any difference from point of view whether they comply with today's standards or not. And of course if the flat had been completed after RCDs became mandatory and was now found to not have them, and the installation had been claimed compliant at the time of installation, that would be an interesting conversation to have with the people involved.
    I have serious doubts of the competence (or motives) of this guy who did the inspection, as I asked him on Thursday to break his lump sum quote (which far exceeded one month's rent, and this is a one bedroom flat in London we are talking about) to line items & cost and give me sufficient detail on each, and he is yet to come back to me. I think another look and a quote from somebody who takes a bit more pride in his work will be a good idea.
    Thanks,
    Sarah
  • Where has the rest of this thread gone?
  • And of course if the flat had been completed after RCDs became mandatory and was now found to not have them, and the installation had been claimed compliant at the time of installation, that would be an interesting conversation to have with the people involved.
    The 17th Edn was published in 2008, but the electrical installation may have been designed whilst the 16th Edn was still current.
    I think that it would be very useful to see a photograph of your consumer unit please.
  • It's in a development of five or six blocks and several hundred flats and mine was the last block that was completed and handed over. Originally move-in date was going to be in 2007, but it got postponed several times due to snagging issues. So it is certain that the design was made well before 2008.
  • It appears that every time I mark a comment helpful, it disappears until moderator has reviewed and re-published it.
  • Is that view the accepted legal practice, though (i.e. by case law)? I'm not a legal professional, so I won't make that statement (or advise of one contrary, without suitable disclaimer).
    Hence, I would ask a legal professional for their opinion on this issue, as to case-law and how this is really dealt with in real legal cases, rather than trying to interpret or theorise oneself.
    Yes. This Open University article describes the rules of statutory interpretation well. The rules are the same elsewhere in UK.
    I am not a legally qualified, but I have a law degree and was a member of the judiciary for a number of years.
    Landlords have a right of appeal to the First-tier Tribunal and thence to the Upper Tribunal. Decisions are half in the National Archives. A search for the phrase, "electrical safety standards" revealed no cases concerning ESSPRS, but a case in the High Court is interesting: Coastal Housing Group.
    It appears that in Wales, a contract-holder (i.e. a tenant) may withhold rent for a property which is not fit for human habitation. Fitness is defined in R. 6 of the "Fitness Regulations". Interestingly, here the "electrical safety standards" are defined as, "BS 7671:2018+A2:2022". Moreover, in the original Instrument, they were, "BS 7671:2018+A1:2020". The amendment was on 30 Nov 2022.
    So, whilst this is Welsh law, it does demonstrate the legislature's capacity to amend statutes when circumstances change.
