section 714 outdoor lighting -two IP specs understanding
Hello folks - good evening
≥ IP 2X stated in 714.411.2.201 (basic protection) when access door open
≥ IP 33 stated in 714.512.2.105 (external influences) for electrical equipment
Is it to be read as the 33 for when gear is not enclosed and behind access door eg. inside lighting column , where it can be 2X … or ?
Thank you
Habs
  • psychicwarrior:
    Thank you
    Habs
    I suspect that there are curious extra regulations for the boys who run around in their maintenance lighting waggons…
    However,
    I read it as 2X when the door is open and 33 generally when the door is closed.
    Legh
  • That is a sensible interpretation. At least until someone  removes the covers and fails to replace them and it starts to rain !!
    This is much the same as the query a few days ago about pollution (well conductive dust) levels in an industrial setting - if the door on the cabinet keeps it out then inside the box is not really part of the hazardous environment.
  • Legh Richardson:
    However,
    Legh
    Should it have just been stated as IP33 then (no mention of 2X), or is there some subtle reason for it I have missed ?
    As mentioned, I read it as IP33  for equipment not contained, but for that inside the ‘enclosure’ behind the door (whether open or not) IP2X …  but it is odd …
  • The two clauses are looking at different things. Generally, the enclosure should be at least IP33, which protects against rain and objects > 2.5 mm.
    However, basic protection of IP2X safeguards workers from shock, perhaps when re-lamping. So no naked busbars in there please.
  • Chris Pearson:
    that seems fair enough.
    taking street lighting columns (im not really familiar with the gear inside the base), is that connection equipment required to be ≥ IP33 and above, or can it be  standard 2X  gear only if the base is IP33, or can it be 2X regardless … are lamp posts IP33  as an aside   ?
